No GZIP?
Daijoubu
Why isn't GZIP enabled??
50kb of HTML can be compressed down to around 8kb!
Yes there's a small overhead, but the size reduction and download time is lowered by ~75%!
You can also lower the compression to level 1 CPU usage bothers you and still benefit most of the compression
.htaccess:
php_value zlib.output_compression_level 1
PHP:
ini_set ('zlib.output_compression_level', 1);
And this server softwares are really behind
This box's still running Apache 1.3.26 which have many known vulberabilities, lastest is 1.3.29
http://www.apache.org/dist/httpd/CHANGES_1.3
PHP4.2.3? Plently of bugs have been fixed. 4.3.5 is in RC3 and lastest stable version is 4.3.4, which is out for awhile already
http://www.php.net/ChangeLog-4.php
For extra performance:
http://turck-mmcache.sourceforge.net
I have no idea which version of MySQL you're running, but i guess it's 3.58.x
Newest production level is MySQL 4.0.17 which feature query caching and helps alot with performance
http://www.mysql.com/downloads/mysql-4.0.html
http://www.mysql.com/doc/en/Query_Cache.html
I already told iceedtea about that, for phpbb, you can install a template cache which also speeds up the board and only takes about a minute to install!
http://phpbb.com/phpBB/viewtopic.php?t=125251
